I've a feeling I'm missing something with video skins
I ripped apart waveform ribbon Vskin, and now want to save it under a new name but every time I rename the xml or the folder the xml is in the skin stops being visible, is there some procedure I'm missing?
second question do vSkins have oninit, I tried and it didn't work
geposted Wed 06 May 20 @ 3:43 am
AH YES !!!
after some month someone finally confirm ^^
there is a bug, related to ... image
in a way a Vskin to be visible, an image with its name must exist
or it have to define an image=..." parameter
often a ripped Vskin have issue showing video
zipped it works another way unzipped
geposted Wed 06 May 20 @ 4:04 am
that got it, [added image="" back in] I still don't really understand, how the skin worked before with transparent.png unreferenced with the xml named as original, but it works now.
geposted Wed 06 May 20 @ 4:38 am
