As not to clutter the "video work" thread, post any video skins in progress, or if you have an idea post a m$ paint mockup
3*3 grid so the aspect ratio remains good
video master in the odd slots, deck 3 north south, deck 4 west east
geposted Sat 16 May 20 @ 8:38 am
really close to my old videoskin "JustVideos" 3x3 video matrix with selectable videos & shapeable by script
where all 9 positions can have its own video (one per deck if needed) its own shape and transparency/visibility (and mixed if transition multiadditive is available)
and center can be full 1/2 1/3 or 2/3 bottom/top 2/3 right/left centred/left/right/top/bottom
mask being in an external png
only the deck/chan number... in a variable, shape in another and level in a third one (pad created to ease with that)
QnD one showing a lot
https://1drv.ms/u/s!AnSOFuC3eKrugzHkX1r12_SLdIQp?e=N9QZxT
badly all already posted images disapeared from old posts
https://www.virtualdj.com/forums/229058/VirtualDJ_Skins/VideoSkin_3x3_videos_matrix.html
https://www.virtualdj.com/forums/230990/VirtualDJ_Skins/placeholders_and_video_with_clipmasks_.html
https://www.virtualdj.com/forums/231013/VirtualDJ_Skins/video_and_cropping_color_mask_differ_in_32bit_and_64bit.html
geposted Sat 16 May 20 @ 10:04 am
9 independent video decks, you crazy man, I like the idea of the clipmask on the first picture.
geposted Sat 16 May 20 @ 10:08 am
in fact it was designed for a up to 8 decks skin with 8 external videos, the bigpad with its 4x8 sliders and 4x8 buttons
for each external screen 2buttons to select +/- deck 2buttons to select +/- shape
sliders for window visibility, osd visibility, mix and global visibility
selection of 9th insert being done with pad parameters 1 & 2
menu for all on/off and doc
everything being scriptable
shapes being in a png, skin have to rename for use with other set of shapes
i was thinking you got it already, sorry it was on my server but i loose this one without notice
was uploaded last year but rejected
geposted Sat 16 May 20 @ 10:23 am
and yes crazy man either
geposted Sat 16 May 20 @ 10:24 am
live automagically updated ASK chat :)
geposted Mon 18 May 20 @ 8:26 pm
