Recently I switched from other DJ soft to VDJ. I use Deezer for online music and don't have other subscription like iDJ Pool. I want to show only Deezer results for online music. So I checked Deezer everywhere in VDJ browser (Online music, GeniusDJ, Live Feedbeck folders).
Now, when I search Online Music folder it shows only Deezer results but on GeniusDJ and Live Feedback folders it shows also results from iDJ Pool and there is no way to tell that song is from which catalogue. It is very annoying, especially if it happens during party.
So my question is - Is there a way to globally remove search results from iDJ Pool?
geposted Sun 17 May 20 @ 7:49 am
Do you see where, next to the Deezer folder in VDJ, it says "personal use only"? That means you should not be using it to play music in public at parties.
geposted Sun 17 May 20 @ 7:58 am
Excuse my English friend he likes to find fault in everything, everyone posts.
If you've done that already, let me know and I'll see if there's another option, but I can't think of one at the moment.
In settings, under options. If you search online catalogs, double check that you only have Deezer in this box.So my question is - Is there a way to globally remove search results from iDJ Pool?
geposted Sun 17 May 20 @ 12:07 pm
Thanks :) Forgot to mention, that I've did that also. With Deezer in Online Catalogs anyway iDJ search works. So maybe there is another way ..
geposted Sun 17 May 20 @ 2:00 pm
Had this perfectly working. Until i updated to latest Version. Now again only idjpool pops up and no deezer at all . Can i go back to previous Version? Or is there a fix?
geposted Thu 13 Jun 24 @ 10:19 pm
try going back to a previous build and see it fix your problem. https://virtualdj.com/download/build.html
geposted Thu 13 Jun 24 @ 11:47 pm
Deezer works OK here, on the latest VDJ version. Search, load, play all working.
geposted Fri 14 Jun 24 @ 12:56 pm
Same problem :(
geposted Tue 12 Aug 25 @ 9:39 pm
