i notice that in the starter and essential skin there is a 'mix fx' button why isnt it available in pro and performance skin? i find it a useful feature and would love to see it in all the default skins since i basically use the pro skin . I also would appreciate an option to show/not show CD art in all default skins. I have noticed that if you activate the mix fx button in i.e. the starter skin and than switch to the pro skin it is active in the pro skin too. unfortunately switching between skins while being live often makes VDJ crash on me.
thanks,
thanks,
geposted Wed 20 May 20 @ 4:48 am
pro and performance have custom buttons you could add a mixfx switch there.
effect_mixfx_select
effect_mixfx_select
geposted Wed 20 May 20 @ 5:01 am
Thanks , I did have to add a bit to be able to switch on and of and make the selection "effect_mixfx_activate & effect_mixfx_select"
geposted Thu 21 May 20 @ 5:30 am
Hey can I use virtual DJ with the Numark NS4 FX
geposted Tue 02 Aug 22 @ 7:20 pm
