i would like to have a list of song suggested .When i select a song in title columnin browser i would like to see in right place (like info view , or sideview) , and i can write this suggested song.. i mean for example , i select billie jean in title column , this song have in tag (like comment) a couple of songs (that i filled) i can play next (like a virgin for example , a list i can read in one vision (like info view) . i mean a sidelist with comment tag where i can write next songs. is like a reminder song i played before. Now i use comment tag to do this , but is too small , only 1 line
hope you understand, thanks
geposted Fri 22 May 20 @ 2:22 am
Already available.
Lookup Cloneview or Sideview in the manual.
You can add the filter folder 'Compatible Songs' to the sideview which will update a list of suggestions (50 songs) according to the current song playing. It takes 45 seconds to update, this can be changed in the settings delayHistory=45.
You can switch on/off the tabs in the Dot menu in the bottom right corner. For instance, I never do Karaoke, so, I have that tab is disabled.
Checkout 'Live Feedback' also in the manual.
geposted Fri 22 May 20 @ 8:00 am
Regarding live feedback, this may inspire you
geposted Fri 22 May 20 @ 8:12 am
The above advice aside, you're wanting a dynamic shortcut to a playlist or Vfolder of trackName in which you can add or select songs follow on to. So a linked track system.
I can see the use but fear it might become an echo chamber of same old same old.
geposted Fri 22 May 20 @ 8:31 am
