I have recently purchased the Numark Mixtrack Pro FX and I have the Pro-Infinity License.
I do not see the configurations as you would for the Mixtrack Pro 3 etc to select in the audio settings of Virtual DJ.
Need some help here and thank you for your time.
geposted Sat 23 May 20 @ 1:31 am
geposted Sat 23 May 20 @ 1:33 am
Not yet supported. Will be soon
geposted Sat 23 May 20 @ 5:06 am
Thank you kindly and best regards!
geposted Sun 24 May 20 @ 7:18 pm
is the Numark Mix Track Pro FX supported yet?
geposted Wed 01 Jul 20 @ 2:01 pm
Yes it is,
top tip if you want to see if something is supported check the mappings section >>show all compatible controllers
geposted Wed 01 Jul 20 @ 2:17 pm
http://www.virtualdj.com/products/hardware.html?view=recent
geposted Wed 01 Jul 20 @ 4:07 pm
