Version 1.1 now available but may take sometime to populate
- Support for new waveforms in VDJ 2021
- Fixed bug for text height when using Metal on MacOS
geposted Thu 18 Jun 20 @ 5:49 pm
So what's changed with the waveforms in skins?
I can see there are lots of small dots below the songpos...
geposted Thu 18 Jun 20 @ 5:53 pm
Primarily how the colours are specified.
The bright dots/lines indicate the beat in the track. When there are no lines then its a break (or section with no kick)
geposted Thu 18 Jun 20 @ 5:56 pm
Who's going to be first with a skin that has five EQ knobs then? :-)
There must be new code for that, I guess.
geposted Thu 18 Jun 20 @ 6:09 pm
It doesn't work like that.
But you'll figure it out. Actually existing skins are capable of showing the three alternatives to High/Mid/Low.
The other two are only available on controllers.
geposted Thu 18 Jun 20 @ 6:12 pm
You can actually create a skin that has both five knobs using the "stem" action, as well as 3 for the regular eq's using eq_low_freq etc...
geposted Thu 18 Jun 20 @ 6:14 pm
Is the skin code in the wiki yet?
geposted Thu 18 Jun 20 @ 6:17 pm
Not yet.
geposted Thu 18 Jun 20 @ 6:19 pm
eq_mode to get the popup, and high_label, mid_label, low_label for the knobs to show the correct text. :-)
Now we know that this new stuff is only 64 bit, if a skin is designed with the new code, is it backward compatible with VDJ 32 bit?
geposted Thu 18 Jun 20 @ 10:27 pm
Custom buttons seem to be bugged on the right deck. Title does not display correctly, or at all in most cases. seems to mirror left deck title. Buttons function, but name is bugged. Left deck appears to be OK
Love the skin Dan! Kudos.
geposted Wed 15 Jul 20 @ 4:17 pm
En el Blacksheep pro al Lado izquierdo oh plato izquierdo no tiene opcion para los Stems, podrian actualizar esta area?
geposted Wed 29 Jul 20 @ 12:07 am
Loving this skin! really appreciate your work. Coming back to VDJ after 10 years lol. Quick question. Where can I find the TAP to set the first down beat on this skin?
Thank you very much ahead of time for your help.
djwillymix Miami Florida
geposted Thu 10 Jun 21 @ 2:13 pm
Hi Dan,
Enjoying the skin, but I found a couple of bugs.
geposted Tue 05 Oct 21 @ 6:34 pm
