Discussion about BlackSheep Pro VS
geposted Tue 26 May 20 @ 4:07 pm
Companion Video Skin
To make changes to layout/color etc you will need the Blacksheep Pro main interface skin.
I will look at creating a pad page to enable amendments without having to use the skin.
Once set however, you can change the main interface to anything you like.
geposted Tue 26 May 20 @ 5:51 pm
pending review
Pad page has now been upload. You will then be able to control the video skin without the main BlackSheep Pro interface.
geposted Wed 27 May 20 @ 1:18 pm
Thank you Dan, i like the 3 screen option that is available.....
geposted Thu 28 May 20 @ 10:20 pm
Dan (djtouchdan) wrote :
Can I find a video on how this is setup?
geposted Sat 30 May 20 @ 9:00 am
Love this companion... Is it possible to add a button for Video plus Slideshow only no CAM? Thanks
geposted Sat 27 Jun 20 @ 10:54 pm
Al editar el skin, dónde se agregan las redes sociales...????
geposted Wed 18 Nov 20 @ 7:56 pm
See here: https://www.virtualdj.com/wiki/BroadcasterGFX.html#socialmedia
The skin uses same logic as the Broadcaster GFX skin
geposted Wed 18 Nov 20 @ 8:15 pm
Bonjour/Bonsoir
je n'arrive pas programmer ce skin si des gens peuvent m'aider je suis preneur
merci d'avance
merci d'avance
geposted Sat 08 Jul 23 @ 7:43 pm
