Forum: Addons
Topic: Broadcaster GFX - Boilerplate (videoskin) - Page: 1
Discussion about Broadcaster GFX - Boilerplate
Boilerplate template with multiple views, for broadcasting.
Use companion controller pads to set and change video output views.
Get pads here : https://www.virtualdj.com/forums/235205/addons/BCaster_GFX.html?page=1
For Slideshow ambient video backgrounds :
http://www.virtualdj.com/plugins/index.html?addonid=81124
HOW TO USE
To learn how to use, see here:
https://www.virtualdj.com/wiki/BroadcasterGFX.html
Update June 2020 :
- easier one-click dual camera operation
- automatic cycle through views
- optional backgrounds with Shader FX
- optional extrabox (for ScreenGrab FX to screen record a live chat etc)
- color scheme
and more....
geposted Wed 27 May 20 @ 6:14 pm
Rune... Will the GFX have the song and artist display like it does in the UI-01 version in future updates?
Will add that ;-)
ciao.. puoi dirmi come faccio vedere i commenti della diretta nello skin?
How to edit/delet youtube and twitter tag, or write other text without the icon.
Read the thread. There's a link with HOW TO USE written above it.
i have Read, and don't realize about messagebox ....thanks
Now my doubt is about screengrab, i want to show in the 3box the chat from facebook..
I test youtube but, the tabs appear toguether..
You have to resize and position the screengrabber plugin over the chat area :)
There is only option to "position" that is possible to move or resize but it works like a zoom , its not the same as cut a border of image.
I haven't been able to do it this way yet
Seems resize the grab area is only implemented on the Windows side currently.
Will hopefully come to the mac plugin soon (mac grabs whole window as of now, if I remember right)
When using the shader as a background the shader does not change, is there a way so it cycles through all my shaders during a set?
Hi
I can get the screengrab to work but it is always in the screenbox 1. I want it to be in the 3:d sceenbox. How should i do?
Im to fast :-) Needing 4 deck layout, right?
The "Extrabox" is a bit of a "work around/hack" to have something extra show.
So to use that, you can for example activate a video FX on deck 4, then switch back to deck 2 after.
To show a screen grab, or something else.
Forgive me if this does not apply but can the Broadcaster GFX be used if I wanted to broadcast a mp4 file? The file is an hour long.
Sure, just load that mp4 to deck and play it...
Or if intended to be as background or in the "extrabox", load that video file in Slideshow video fx in the software
56%
