Forum: Addons
Topic: Broadcaster GFX - Neon (Theme) - Page: 1
geposted Wed 27 May 20 @ 9:57 pm
nice i'm sure this will help out a bunch of people
geposted Thu 28 May 20 @ 12:06 pm
- Two main "boxes" : Master Video + Camera - or - Camera + Camera (show 2 cameras at same time)
how can i use two cameras ?
geposted Fri 29 May 20 @ 9:16 am
NicotuxHome userMember since 2014
for now only one camera at a time can be selected as a video-source (main video effect) (both displays being the same)
so that the solution is to select the second one as overlay effect on a deck
geposted Fri 29 May 20 @ 9:35 am
Currently, this uses the 4th deck for the second camera.
So make sure you are on the Pro/Performance layout, and just click the button, thats it :)
To change the 2nd camera, just use the camera effect on the 4th deck, and change source in the effect settings on the 4th deck.
This will be MUCH easier in next software update, where its no longer needed to use 4th deck ;-)
geposted Fri 29 May 20 @ 2:13 pm
defmdPRO InfinityMember since 2020
Love this one and the controls that come with it. No need for OBS using your skins.
geposted Fri 29 May 20 @ 5:47 pm
Great skin, love how customisable it is!
I'm intrigued though what is 'Show Extra Box' for?
geposted Sun 31 May 20 @ 1:31 pm
For example if you use Twitch, you can overlay the chat box there.. or tips coming in or new joiners etc..
But will probably also make it work for 3rd cam, when users have 3 cam.. its more a "get creative, use as you want" extra box currently ;-)
geposted Sun 31 May 20 @ 3:52 pm
For the extras it would be great if we can use it for the screen grab. Screen grab is currently alligned with the main video screen and looks a bit weird when you change the screen sizes. Would be nice if we can place it somewhere in a corner for chat overlays e.g restream chat.
geposted Sun 31 May 20 @ 11:22 pm
yeah true, could be nice, maybe will be added ;-)
geposted Mon 01 Jun 20 @ 7:41 pm
I dot know where to custom the codes text. You explanation do not tell us where to go to make the edits.
geposted Sun 07 Jun 20 @ 1:43 pm
geposted Mon 08 Jun 20 @ 3:18 pm
geposted Sun 14 Jun 20 @ 12:56 am
593harbyPRO SubscriberMember since 2014
estimados esto esta genial ... !!! pero llevo varias horas intentado de todas las formas posibles y no puedo poner mi nombre en las redes tal como están indicando en las instrucciones, no se que estoy haciendo mal ... si alguien me da una mano le quedo agradecido
geposted Sat 11 Jul 20 @ 2:19 am
See here https://www.virtualdj.com/wiki/BroadcasterGFX.html#socialmedia
Maybe easier to understand from the guide ;-)
geposted Sat 11 Jul 20 @ 10:42 am
djmilaPRO InfinityMember since 2008
+1 for screen grab Add
geposted Mon 13 Jul 20 @ 11:17 pm
Rune when you have multiple cams is it possible to select which cams e.g extrabox by modifying the code slightly, if so how? Is this done by changing the index?
<panel class="showVideobox" x="78" y="78" width="1104" height="621" source="master" visible="var_equal '@$broadcasterGFXdualcam' 0"/>
<panel class="showVideobox" x="78" y="78" width="1104" height="621" source="camera" index="1" visible="var_equal '@$broadcasterGFXdualcam' 1"/>
<panel class="waiting" x="78" y="78" width="1104" height="621" text="Waiting for camera" visible="not video_fx 'camera' && var_equal '@$broadcasterGFXdualcam' 1"/>
<panel class="showVideobox" x="78+78+1105+15" y="78" width="564" height="317" source="camera" index="0"/>
<panel class="waiting" x="78+78+1105+15" y="78" width="564" height="317" text="Waiting for camera" visible="not video_fx 'camera'"/>
</panel>
geposted Wed 05 Aug 20 @ 4:46 pm
geposted Mon 10 Aug 20 @ 2:48 pm
este es el codigo correcto para cambiar los nombres, solo Cambiar la red Social y colocar su nombre de la red social.
set '@$youtube' `get_text "Your Facebook channel"`
geposted Wed 07 Oct 20 @ 4:43 pm
How can we chage text, for ex..
Remove twitter and add Whatsapp phone number?
Thanks.
geposted Thu 15 Oct 20 @ 12:11 pm
38%
