Hello, Support,
as I was informed by the support on request there is currently NO possibility to press the TAB key in the text editor to reach the "OK" key.
This means that whenever you edit the file info, you can either negate the entered text by pressing ESC or use the "OK" key to confirm the new entry
MUST use the CURSOR, because one (to me known alternative WITHOUT cursor) probably does not exist.
Please
A) Inform me about the accessibility of the „OK/SAVE-button" WITHOUT using the cursor
B) this in a next UPDATE with maintain.
Most sincere thanks
DJF*
Please
Most sincere thanks
DJF*
geposted Sat 30 May 20 @ 1:55 pm
Which text editor are you talking about exactly?
On most dialogs you can press Enter to apply.
geposted Sat 30 May 20 @ 2:24 pm
what you want to move through the different options of the window is done with TAB but to modify you do it with the space bar and with the up and down arrows
geposted Mon 01 Jun 20 @ 10:21 pm
Hi, now I find the system.
Thanks
Thanks
geposted Wed 10 Jun 20 @ 8:42 pm
