I use VirtualDJ 8 with Live365 for live shows. My metadata shows incorrectly on the 365 player during live shows, but it's fine with my feed from SAM Broadcaster for the rest of the time. Is it possible I have an incorrect setting in VDJ ? This is just a desperation inquiry because 365 always says everything is fine on their end, so I'm just grasping at straws. Thank you for any insight.
geposted Thu 04 Jun 20 @ 3:18 am
are the tags in your files correct?
geposted Thu 04 Jun 20 @ 11:36 am
