Hey guys. I have a launchpad pro and it has worked for ever. but now i pluged it in and i cant use it! the mapper is on a custom mapper with nothing mapped and i cant find out how to get the default mapper back to it. I tried reinstalling over the old copy of virtual dj, didnt work. :/
thanks
also
if anyone knows how to make the lights on the pads turn on when programing your self that would help.
tried looking for those to and couldn't find the pads or the leds
thanks
also
geposted Sat 06 Jun 20 @ 4:46 pm
You want to use the default mapper, or the custom one? Your post isn't very clear.
If you delete (or rename) the custom one, that should get you back to the default.
geposted Sat 06 Jun 20 @ 4:50 pm
sorry. :) I want to use the default mapper. Thanks
geposted Sat 06 Jun 20 @ 5:01 pm
The custom one will be in Documents\VirtualDJ\Mappers. Delete it and VDJ should revert back to the default one.
geposted Sat 06 Jun 20 @ 5:07 pm
So I went to Virtual dj/documents/mappers and deleted it. Then the custom mapper reappeared when I restarted VDJ.
still no default mapper
only thing that remains is
SIMPLE_MIDI_0_0 - Custom Mapping.xml
geposted Sun 07 Jun 20 @ 11:50 pm
if it's seeing it as simple midi it means it hasn't been pickup as what it really is first point of call is drivers, next might be
search options for
definition
you should have this set to NO
search options for
definition
geposted Mon 08 Jun 20 @ 1:06 am
Tested both Windows 10 and Mac 10.15 and device is properly detected as shown here http://www.virtualdj.com/manuals/hardware/novation/launchpadpro/setup.html (3 devices) with factory default mapping.
From VDJ Options make sure you have disableBuiltIndefinitions to No.
Try a different USB port, and see if using the Power adapter helps (works without here though)
Any chance some other application is running in the background, taking control of the unit ?
Also check your /Documents/VirtualDJ/Devices folder and see if you have any custom definition for the device or any related file that should be removed.
geposted Mon 08 Jun 20 @ 9:30 am
just checked and DisableBuiltindefinitions is set to no
tried a usb port and it didn't work
i just reinstalled vdj and its still the same
i just fixed it.
there is a midi setup app for mac. it was interfering with it.
Thanks for all the help. i appreciate the quick response!
i just fixed it.
geposted Tue 09 Jun 20 @ 12:58 am
