THE FUTURE OF DJING IS HERE NOW !
VirtualDJ 2021 uses advanced technology and the power of modern computers to revolutionize what DJs can do.
Introducing real-time stem separation on any track, making perfect live mashups and seamless transitions the new normal.
Like usual, the update to VirtualDJ 2021 is completely FREE.
Go to virtualdj.com/download to grab your copy today.
Enjoy !
Enjoy !
geposted Thu 18 Jun 20 @ 6:35 pm
Please stop resetting the skin, padding and auto pitch / BPM setings every time there's an major update.
We know the features are there so stop forcing them.
geposted Thu 18 Jun 20 @ 7:15 pm
hi where find stems?
where did you have website to buy?
thanks
thanks
geposted Thu 18 Jun 20 @ 7:54 pm
No, it doesn't play stems. Just play a normal track, and use the new EQ to isolate the different parts.
geposted Thu 18 Jun 20 @ 7:56 pm
Should I download it and install it to upgrade?
Is it going to overwrite the existing build already installed? Or will it be installed aside?
geposted Thu 18 Jun 20 @ 8:04 pm
So I selected the EQ method when it asked and realize I want to change that now, is there a way to get to the picture with descriptions again? I think I found the settings but I as usual didn't read the description so want to see it again, or if someone can screenshot that and post it thanks
geposted Thu 18 Jun 20 @ 8:07 pm
It's the little button to the right of the top EQ.
geposted Thu 18 Jun 20 @ 8:09 pm
thanks
thanks
just play any audio file and it will create the stems automagically for you. all for free, nothing to buy.
geposted Thu 18 Jun 20 @ 8:10 pm
yes, it's going to overwrite the 2020 version.
if you want to keep both in parallel, copy your virtualdj.exe from program files to virtualdj2020.exe, before doing the install.
geposted Thu 18 Jun 20 @ 8:11 pm
geposted Thu 18 Jun 20 @ 8:12 pm
system requirements?
geposted Thu 18 Jun 20 @ 8:16 pm
There was indeed a small bug in the current release, that resets some settings when upgrading from 2020 to 2021.
It's been fixed now and a patch will be available soon.
geposted Thu 18 Jun 20 @ 8:32 pm
Cool
geposted Thu 18 Jun 20 @ 8:46 pm
Stephane Clavel wrote :
By Me is no Button there in the Default Skin?
geposted Thu 18 Jun 20 @ 8:49 pm
skin Default
geposted Thu 18 Jun 20 @ 9:00 pm
LIMOL wrote :
skin Default
By me is not this Button in Default Skin ...
geposted Thu 18 Jun 20 @ 9:05 pm
can you show us a picture here
geposted Thu 18 Jun 20 @ 9:10 pm
Have you checked that you're running VDJ 8.5 b5918?
geposted Thu 18 Jun 20 @ 9:11 pm
Yes , Install over old Version.
Cant als find no Stem Pads or a new Vocal Color Fx.
Only the Options are new , and a Pair of Mapper Commands.
Waves are also not new I can see..
Here screenshots.
Or is there a diverence on 32 bit version?
Here screenshots.
geposted Thu 18 Jun 20 @ 9:21 pm
Yes, although the build number is the same, the 32 bit version is named 2020 and 64 bit 2021. Seems they are different.
That's going to confuse people.
geposted Thu 18 Jun 20 @ 9:25 pm
