Since upgrade to 2021 everytime I open VDJ, a message box pops up saying "cant load math engine"
It works, but if I click on calculate stem VDJ crashes
geposted Thu 25 Jun 20 @ 10:42 pm
Give us some info about your computer.
geposted Thu 25 Jun 20 @ 10:44 pm
AMD Ryzen 1700, 16gb ram 1tb ssd RX580
2014 Macbook Pro 8gb ram 256gb ssd GT650m
Both Windows 10.
I also don't use the default vdj database location
Both Windows 10.
geposted Thu 25 Jun 20 @ 11:26 pm
I think both grafic cards are not supported.
Change mathEngine option to CPU and you shouldn't get the error message while still be able to use the stem feature.
geposted Fri 26 Jun 20 @ 5:55 am
That worked!
Thanks
Is there a list of supported graphic cards anywhere?
geposted Fri 26 Jun 20 @ 12:48 pm
Unfortunately not. All we know is that it has to be NVidia, and the GTX 1650 & 1660 are good choices.
geposted Fri 26 Jun 20 @ 1:00 pm
Great!
My actual djin laptop has a 2070
geposted Fri 26 Jun 20 @ 1:01 pm
One of my laptops has a GT720m and is able to use the GPU for stems processing.
So I think the Nvidia 7xx series is the minimum if your 6xx doesn't work.
geposted Mon 29 Jun 20 @ 7:24 am
It would be good to have list of proven "GPU capable" cards/computers - even if we have to do it ourselves.
geposted Mon 29 Jun 20 @ 7:34 am
Where is the option to look up math engine? I'm suffering from the delay in the audio beat and the beat lagging in the visual wave form thing too. Is the math engine changing setting IN virtual DJ Pro? or is it in the PC? Where do I find it?
Running Virtual DJ Pro 8
Ryzen 5900x CPU and RTX 3070 GPU with NVME drives for windows.
geposted Sat 18 Mar 23 @ 8:15 pm
