Topic: Reloop RMX 60 and Numark Ndx 500
Hey guys,I have the Numark Ndx 500 Cd players, and I want to buy the reloop rmx 60 mixer.. So my question is that if I only have to plug the USB of the reloop, use its soundcard, then just change in the audio section the decks 1 and 3 into Ndx 500 and I should be able to control the Vdj with it? Or there is something else?
geposted Mon 29 Jun 20 @ 11:16 pm
Even though the Reloop RMX60 doesnt offer MIDI or a USB Audio Interface, the NDX 500 have built-in sound card, so you could use this setup with VDJ without need of any other gear.
Here is how you need to setup .. https://virtualdj.com/manuals/hardware/numark/ndx500/setup.html
Now the only "issue" with this setup is that you cant control the internal VDJ mixer, meaning that the mixing is done by the Reloop mixer and it's applying its own Volume, Gain and EQ, so you wont be able to to use the new Stems EQ of VirtualDJ.
No DVS with the Reloop 60- in case you were interested.
And of course, you will need a Pro license too.
Thanks for answering me guys...
So as i see it my only option is to buy the DJM-450 because i want a mixer with fx.
any suggestions guys?
