Topic: upload: last updated not updated
addon upload & update is done ok
but in extension page as "last updated" date there is still the "first uploaded" date
(which make it wrongly listed when sorted by date)
https://imgur.com/a/6U1YehN
As you can see description is talking about VDJ 8.5 and 2021 and stems but "last updated" date is still ... 2019-11-08
which is not possible as VDJ 8.5/2021 and stems were not released last year near 11 month ago ^^
geposted Wed 01 Jul 20 @ 11:38 pm
Which Addon is this ?
Not sure what happened, will keep an eye on next updates.
Your Addon shows current date now.
Thanks
as previously:
some recenty updated skins and plugins show as possibly updatable, new comment, new picture if any... however their "last update date" goes on not being updated :\
New update, same issue :(
by the way, some other uploads get [PLEASE PROVIDE IMAGE] or [TEAM: Please provide an Image for your Addon]
even uploaded and uploaded again with different images
as well as for new one... language still 2 updates missing
by the way ... other "PROVIDE IMAGE" still appear even uploaded again
and some other addons come corrupted/old/bad uploaded version
"Ma bibliotheque" is not usable/installable anymore and provide a buggy thing
"VB_8Decks" back to initial version
"JukeBox_2020" old version
"VintageView"
"MARS" & "VDJPlugin" "PAD_SHAPES" update pending forever
VdjPlugin will be renamed to "VDJPlugSkin", version 1.3 uploaded since a while
BUT ID DOES NOT ENTER ANY EXISTING CATEGORY
it does nothing, but provides an extra gui : almost anything you want to create as a skin
Is it a plugin : yes
a skin ? not really maybe consider a skin but must load as a plugin
an effect ? no but act as one (doing nothing but providing a skin)
is it other ? maybe
language ? no
database ? no
mapper ? no
a tool ? maybe but it is not an executable, there are 32bit & 64bit dll to be loaded as a plugin
send as audio plugin, because it's the most easy way to find it but....
may install in autostart withyout problem - but how to provide one ? and what about home users ?
Your Language file French_Vdj_2020_b5308 Last update: Thu 02 Jul 20 @ 4:03 pm
What is wrong, the file or the Update date ?
Have you submitted an update after that ? Dont see any. Can you re-upload ?
"VB_8Decks" skin shows Last update: Tue 04 Aug 20 @ 12:28 pm File: VB_8Decks_5.2.zip Version 5.2
What is not correct ?
"Ma bibliotheque" is installing fine here. There is an issue with some unicode characters though, but works.
As for the VDJPlugin, not sure how average users can use that as .. 1)It doesnt select zip files, by default it seems to require xml files 2)It doesnt seem to correctly converting several skins to a window when it comes to some positions, radius etc.
And yes, it doesnt fit to any category, perhaps create your own installer and put it in some "special" folder, like SoundEffects/Other and upload it it as "Tool"
Well ^^ what more to say ? new version (not an update) exactly same issue
Uploaded new one last week to replace French translation https://www.virtualdj.com/plugins/index.html?addonid=81042
which was instant removed from both
the site : plugins&Addons -> Others -> Languages : http://www.virtualdj.com/plugins/index.html?category=other&subcat=1
VDJ extensions : Settings -> Extension -> Other -> Languages
as well as from comments history
New one "Others" -> "French for VDJ 8 to 2021" is French translation https://www.virtualdj.com/plugins/index.html?addonid=81245
which is available to download from here http://www.virtualdj.com/plugins/download.php?addonid=81245
from the site : plugins&Addons -> Others -> Languages : http://www.virtualdj.com/plugins/index.html?category=other&subcat=1
BUT NOT HERE FROM WITHIN IN VDJ extensions : Settings -> Extension -> Other -> Languages
What is the difference with other ones downloadable from both :
last line for those available in VDJ : "Stats" "Comments" "How to install"
buttons for those available in VDJ : "PC" "Mac" "Pc (32bit)"
last line for not available in VDJ : "Stats" "Comments"
buttons for those available in VDJ : "Download"
Clearly indicating it is not installable
