I was wondering if we will be getting the 32 bit effects for V64 bit version. Video Cut, electro shock and Fx Banks are some to mention.
geposted Sat 04 Jul 20 @ 5:06 am
fx banks are part of the app now [have been for months]
effect_bank_load
effect_bank_save
effect_bank_load
effect_bank_save
geposted Sat 04 Jul 20 @ 5:09 am
What about the other effects (i know Scott is working on milkdrop)but video cut? And electro shock?
geposted Sat 04 Jul 20 @ 2:57 pm
for video cut, the native x64 cut effect can also strobe video [check the fx gui], there's also the native strobe if you don't want to effect the sound.
what does electro shock do? [I don't fancy installing, outside of proving x64 shader errors I've hardly used x86 since x64 release.]
it reads like it's a beat aware toggle negative fx, if that's the case padpages ZvideoControl and or SvideoControl can do that.
A virtualfx could do that job too.
geposted Sat 04 Jul 20 @ 3:31 pm
A virtual fx? What do you mean? Haven't played around that much with 64 bit.
geposted Sat 04 Jul 20 @ 5:46 pm
virtualfx is called DIY in extensions page
https://virtualdj.com/plugins/?addonid=81082
locodog's plugin allowing to use functionalities internal/from other plugins in a way to script another composite one
geposted Sat 04 Jul 20 @ 6:33 pm
