You didn't answer my question. As DJ software tends to favour minor keys, I asked how many of the tracks you tested were minor?
To test well, you should have a varied selection of major and minor, and also tracks that contain several keys.
Generally in tests, key detection software is only correct around 70% of the time (or less). Mixed In Key (the "industry standard") can get around 80%.
You're claiming that Rekordbox is 100% perfect, which makes me suspicious.
geposted Wed 08 Jul 20 @ 8:07 am
Hi,
When i will have time, it's not my task to debug VirtualDJ.....on this feature....
I'm not at home because of my work
perhaps in september :)
The soluce i've found is to analyse All my files in Rekordbox, to suscribe for https://rekord.cloud/, and use it to convert Rekordbbox 6 to VIRTUALDJ......
Regards,
Regards,
geposted Wed 08 Jul 20 @ 5:32 pm
geposted Fri 24 Jul 20 @ 5:33 pm
They don't mention which detection mode they were using in VDJ. That's an important factor on the results.
geposted Fri 24 Jul 20 @ 6:06 pm
