Forum: Addons
Topic: Project X - Page: 5
When I am using the Pro skins and I have chosen Effects rack, what should I being seeing on the rack?
You shouldn't see the effects rack (its a bug) - that's for another skin, Project X Slider (coming soon).
1.1.2 (21-07-2020) - approved but may take a little time to populate
  • FIX Remove option to select Effect Rack (not meant for this skin)
  • FIX EQ Kill buttons when using VDJ 8.4 (32bit)
What I do see for one of the VSTs I use looking interesting. I can hardly wait!!
I notice there is a Slider skin viewable from the setting but not from the main Layout section of the skin. It look similar to the Scratch skin on the Layout section, is it for experimental only? Also on the setting the Project X doesn't have a Preview PNG as all the other skins do. Is it by Designed? (Such as Vectro or Blocks).!!!
It was indeed experimental in this form. Project X Slider will be ready soon.
1.1.2a (22-07-2020)
  • FIX Remove slider.xml (not meant for this skin)
  • FIX Skin Preview Image
b1.1.3
  • Remove Musically from Broadcast Menus and replace with PlayDJ:TV
b1.1.4
  • Option to disable broadcast time reminders from the menu (when active and broadcasting)
Hello Dan.
The Eq kill buttons is still not visible in any of the layouts of the 32bit version (using the latest build 6042).
I don't know what else to say. They show for me in 32bit:
This is the latest build from today - but I haven't changed the kill buttons.
b1.1.5(pending review)
- Added option for old school waveform from main menu (labelled Beats with Volume)
n.b. requires build 6059 or higher
Great skin....thnx!
How can i remove or push away the 'info tab' in the browser (most right window)?
grtz
Hey Dan
Did you manage that fix for the jog wheel yet?
I know you said you would try yesterday, Would really love to use for my wedding this weekend.
Thanks
Haven't had time yet. Will look this evening. It's a quick fix so won't take long, but just need to find the time to sit down and do it.
Just a quick question: Is it possible change the actual grey colour when you select a song in the browser?
Thanks Dan
You rock
Hey Dan
Any update on the jog wheel fix... Sorry to be a pain in the ass I just really want to use the skin you put all the work into
Thank you
Thank you for a great skin...
is there a way to modify the "set File Color" to different colors, i use a specific blue/yellow compared to the one's you've assigned to the set color buttons. I tried to modify the XML file but it would return error when trying to open it.
Thanks again...
For info: skin with erroneous xml which are selected as default skin makes VDJ open a dialog box that contains infos about line in error at start of VDJ
very usefull to fix it
(may be fine VDJ to do the same when opening the skin from settings)
i was able to figure out the "set File Color" , thanks again for an amazing skin...
63%
