I downloaded Virtual DJ 2021 from www.virtualdj.com
But my 64 bit win 10 windows installer didn't install it, It failed to install. What is the problem?
geposted Fri 10 Jul 20 @ 6:13 pm
You are on Windows 10 64bit you meant?
And if so, what does the error say when you try install? Or perhaps when you try run?
Direct X - Update video card drivers perhaps?
geposted Fri 10 Jul 20 @ 7:13 pm
Had the same issue I had to update my nvidia drivers and it installed..hope it helps peace
geposted Sat 11 Jul 20 @ 12:50 am
I am having the same issue with a Windows 10 Pro Version, 64 Bit, with an Intel Video Chipset. Tried the video driver update suggestion through Intel without success. Is this something VDJ is aware of and solving?
geposted Sat 11 Jul 20 @ 1:29 pm
Hello:
I tried to install Virtual Dj 2021 on my Mac. It says Failed - Network Error. I do have the latest software installed. Please advise.
geposted Wed 05 Aug 20 @ 11:22 pm
Virtual DJ
geposted Sat 19 Sep 20 @ 6:23 am
Can someone post link of version 2021 please?
Kind regards,
Neno
Kind regards,
Neno
geposted Thu 17 Dec 20 @ 4:27 am
Why not to simply use top banner ?
VIRTUALDJ logo (from homepage big DOWNLOAD button)
or "Download" tab or download menu "virtualdj" ^^
if you want it as a link rightclick and copy link ^^
geposted Thu 17 Dec 20 @ 5:04 am
asks me to open the database ... from where we open
geposted Thu 31 Dec 20 @ 7:30 pm
Sure the message says that?
VDJ either opens its own database, or creates a new one.. ..
Maybe it saying something else, like "Itunes database" or "Database Error,. want to fix?"
geposted Thu 31 Dec 20 @ 8:00 pm
Lboogiemix wrote :
Hello:
I install it on my MacBook, no problems.
Do you have fixed internet ? Is your firewall not blocking Virtual DJ ?
Login to Virtual DJ with your email and password, normally than it must work
Good luck,
Goodlife
geposted Mon 04 Jan 21 @ 2:32 pm
why a virtual dj 2021 is only for windows 10 and not for 7 too i heve only 7
geposted Tue 19 Jan 21 @ 6:50 am
Configuration for VirtualDJ 2021 - Some assistance/experience pls.
Hi I have Virtual DJ Pro 2021, which I am using with a numark mix platinum fx, which works well enough.
I will also be making use of an akai mpd 218 if needed to assign additional keys to.
The issue is I was much more familiar with earlier versions of VDJ, can't put figure on as to why, but I just found it easier for me to sample on the fly, use effects, assign effects to keys etc.
This means I am now using just a fraction of the functionality that I used to and also I am using the mouse and keyboard way more than I had hoped to, the only difference being that the use of stems is super simple.
The aim will be to end up with a more workable standard config, which I can safe for use on both my laptop and my desktop computer
I wonder if anyone can help with a step by step guidance. I would like to achieve the following:
1.) Set up sample library (how to quickly sample live and assign these to pads during a mix)
2.) How to assign functions to the pads and buttons on the MPD218
3.) How to use a midi keyboard to play notes over a mix using the samples.
Any other assistance on a recommended setup/settings that I can copy would be greatly appreciated
geposted Sun 18 Apr 21 @ 6:55 pm
I want tobuy the latest version of Virtual DJ 2021 pro.
So I downloaded the free VDJ and tested this version.
I wll use the software for a great jubilee party and there I need a functionell Version.
With the free version I have some problems with the audio and video channel.
If you can garant, that the new version of the VDj 2021 Pro is working well than I will order.
Franz Bogner
Franz Bogner
geposted Mon 19 Apr 21 @ 8:00 pm
Should work all well yes ;-)
As for audio & video mentioned, I suppose you mean you had a notice that said it required a license (such as advanced audio, video logo etc)
geposted Mon 19 Apr 21 @ 8:11 pm
I did install it, it worked with the numark party mix, for about a week.
Now Virtual DJ wil not work anymore.
If I click the icon it seems like it will start (the sandhour starts turning) 2 seconds and then nothing..
I tried removal, renewal, even erased all the registry entry's and restart, fresh install. Same problem.
I can not open Virtual DJ anymore! HELP
geposted Tue 20 Apr 21 @ 5:52 am
Not sure from your description..
But maybe you are using a corrupted skin or something..
in /documents/virtualdj/ delete the file settings.xml
Then start VirtualDJ and all should be ok ;-)
geposted Tue 20 Apr 21 @ 11:22 am
I have a problem with installing the latest version of virtual DJ...The set up can't be completed and It tells me that there is an error in creating a temporary file that is needed for the installation...I see that many others have also problems and cannot install it...So what i have to do?
geposted Fri 09 Jul 21 @ 2:26 pm
Did you download the installer from here ? https://www.virtualdj.com/download/index.html
Can you please repeat the installation and post here a screenshot showing the message/error you get ?
geposted Fri 09 Jul 21 @ 5:23 pm
i downloaded it from this link and from other but the result is the same...the message says "there was an error creating a temporary file that is needed to complete the installation"
geposted Fri 09 Jul 21 @ 10:44 pm
