How do I disable the "sync" button function in vdj??? My right deck's sync button is toggling on and off. My right deck's sync button also keeps making the right deck's waveform constantly moves (syncs) to the first beat of each phrase of the left deck's waveform while Im mixing. I know its my gemini g4v's right deck sync button acting up. I just want a script custom button code or a way to disable sync
geposted Tue 14 Jul 20 @ 7:27 pm
My guess, if you’re not pressing the buttons yourself. Is you have autoSync switched on. Check settings.
geposted Tue 14 Jul 20 @ 7:34 pm
No am I actually want to disable the sync mapper are on the right deck.
So that way the Right deck waveform doesnt keep beat matching to the left deck which makes my mix offbeat.
geposted Wed 15 Jul 20 @ 1:34 am
There are some settings on the Skin as well as in the Settings dialogue. Untick the Auto stuff.
It's the gear icon next to the Sync button on the right hand deck on the Pro skin.
........and next to the Cue button on the left hand deck;
geposted Wed 15 Jul 20 @ 7:00 am
