Now that there is a precomputed icon, is there also a script for it so you can look for it in filter folders?
Like there is with for instance "Has Edit" or "Is Edit"
I looked for it in the filter folder script page but nothing caught my eye
geposted Wed 15 Jul 20 @ 1:30 pm
I was wondering this the other day and the way the edits work won't work for STEMS as the physical stems file isn't in the library.
Unlike the the EDIT which shows in the library alongside it.
Probably needs something adding to the filter database.
geposted Wed 15 Jul 20 @ 6:03 pm
