i see on almost every skin if you choose the waveform (Monochrome) it defaults to blue & red on the deck waveforms. im trying to do a ref theme. as in i want to make the blue side also red. i opened up the XML file & searched for monochrome & colored waveforms to see if i could find the blur hex color and change it to red but i dont see what anywhere in the lines that say monochrome ? please see my pics as to what im talking about thanks  (Small).jpg)
 (Small).jpg)
geposted Thu 16 Jul 20 @ 12:14 am
<rhythmzone /> and <scratchwave /> have specific color parameters (need testing, not enouch info)
<rhythmzone color="red" color2="green" ....>
<colors
deck1="0" deck1_left="#007097" deck1_active="#009fd2"
deck3="0" deck3_left="#007097" deck3_active="#009fd2"
deck2="0" deck2_active="#cd0f10" deck2_right="#8c0709"
deck4="0" deck4_active="#cd0f10" deck4_right="#8c0709"
</rhythmzone>
<scratchwave deck="left" orientation="horizontal" color="#007097" color2="#009fd2" colorVocal="green" colorNoVocal="DarkGreen" colorInstru="blue" colorNoInstru="DarkBlue" colorBeat="red" colorNoBeat="DarkRed">
<colors
</rhythmzone>
geposted Thu 16 Jul 20 @ 12:44 am
<colors
</rhythmzone>
<colors
</rhythmzone>
the skin im using is Controller by DennYO its one of the more popular skins lots of users use...here's what i have so far, just need to make that waveform blue. as im going for a red theme
geposted Thu 16 Jul 20 @ 2:04 am
i see on almost every skin if you choose the waveform (Monochrome) it defaults to blue & red on the deck waveforms. im trying to do a ref theme. as in i want to make the blue side also red. i opened up the XML file & searched for monochrome & colored waveforms to see if i could find the blur hex color and change it to red but i dont see what anywhere in the lines that say monochrome ? please see my picture as to what i'm talking about thanks
geposted Thu 16 Jul 20 @ 2:07 am
as found in the xml file:
8985 <colors deck1="classicwave1" deck1_active="classicwave1"/>
9005 <colors deck2="classicwave2" deck2_active="classicwave2"/>
9015 <colors deck1="classicwaveoverlaycolor" deck1_active="classicwaveoverlaycolor"
9016 deck2="classicwaveoverlaycolor" deck2_active="classicwaveoverlaycolor"/>
9879 <colors deck1="classicwaveoff1" deck1_active="classicwave1"
9880 deck2="classicwaveoff2" deck2_active="classicwave2"/>
Just redefine in your color scheme all related colors in lines 82 and up to follow your needs :
songposplayed and songposbass and songposmed and sonposhigh and classicwave (per deck dependants) but not used
classicwave1..classicwave4 and classicwaveoverlaycolor and classicwaveoff1..classicwaveoff4
geposted Thu 16 Jul 20 @ 2:40 am
......but the wavefoms in the deck area are not rhythmwaves or scratchwaves - they're songpos waves.
geposted Thu 16 Jul 20 @ 8:05 am
2586 <define visibility="70%" class="songpos" colorPlayed="songposplayed" colorBass="songposbass" colorMed="songposmed" colorHigh="sonposhigh" placeholders="width,height">
that's exactly the same for songpos (just invert the set of color to alter):
classicwave1..classicwave4 and classicwaveoverlaycolor and classicwaveoff1..classicwaveoff4 ( but not used)
geposted Thu 16 Jul 20 @ 8:15 am
not sure hoe to delete a post :-) i figured it out thanks all for your added info
geposted Sat 18 Jul 20 @ 2:18 am
