geposted Thu 16 Jul 20 @ 9:59 am
Do the initials GTS have a meaning? Get This Skin perhaps :-)
Ah, your initials...
geposted Thu 16 Jul 20 @ 10:15 am
I was too lazy to find a proper name for it... :P
geposted Thu 16 Jul 20 @ 10:17 am
hope your new skin has an option to turn off waves ;-) some djs like me see them as just taking up browser space. seeing my songs is the most important to me LOL
geposted Sat 18 Jul 20 @ 2:20 am
geposted Mon 27 Jul 20 @ 8:08 am
Hi George-
Great skin & excellent work !
one question about the Beatgrid lines & dots :
Is it possible to change in the .xml file the following :
The thicknes of the lines (all of them : beat 1-5-9 & beat 2-3-4) & also the size of the dots over them ( with 1-5-9 beeing thicker than 2-3-4)
can it be done ?
if yes where in the code to i have to look & replace it ?
i am attaching a picture of the areas that i would like to replace with the bigger ones.
thanks a lot
can it be done ?
thanks a lot
geposted Tue 25 Aug 20 @ 12:18 pm
Search for:
<define class="wav_SCRATCH_HOR"
and
<scratchwave class="wav_SCRATCH_HOR"
Those are the elements you need to edit.
The width of the grid is easy, just edit <define class="wav_SCRATCH_HOR" and change
to suit your needs
The height of the grid is more complex.
You need to edit <scratchwave class="wav_SCRATCH_HOR" and change (as an example)
and
<grid mainsize="2" size="1"
to suit your needs
gridpos="-5" gridheight="7"
geposted Wed 26 Aug 20 @ 10:44 pm
Can you add Video menu?? This is a wonderful skin!!! Thanks
geposted Thu 10 Sep 20 @ 11:27 pm
Yes, I'm working on it...
geposted Fri 11 Sep 20 @ 12:40 pm
Additional to adding a Video menu can you also add a menu to choose a Waveform such as Mirror wave, Default wave, Scratch wave.??? Great Skin as always your hard work is Appreciated...Thanks.!!!
geposted Fri 11 Sep 20 @ 4:44 pm
Ok just tried this skin and it’s my new go to 🤙🏾
Awesome job!!
Awesome job!!
geposted Thu 15 Oct 20 @ 11:09 pm
Version 1.1.0 (pending review) added Video support.
geposted Sat 17 Oct 20 @ 4:17 pm
My definitive skin! Perfect. Thanks
geposted Sun 18 Oct 20 @ 8:45 pm
I love this skin and have it installed permanently. The one thing that I wish I could do is see the recording time on the top of the window. Is that something doable?
I record a bunch of 30 minute sets and have to rely on going to the preferences.
geposted Thu 17 Dec 20 @ 3:46 am
A new update is coming that has such an option.
geposted Thu 17 Dec 20 @ 7:18 am
Thanks so much for adding this option! It's a game changer!
geposted Fri 08 Jan 21 @ 1:55 am
New layout coming soon...
geposted Thu 01 Apr 21 @ 9:04 am
nice i see stem buttons :-)
geposted Thu 01 Apr 21 @ 12:08 pm
Why is the jog circle so important to everyone? Is it really necessary?
There's so much can be do with that realestate.
geposted Thu 01 Apr 21 @ 5:41 pm
That's why OSD layout exists (on the same skin)
geposted Thu 01 Apr 21 @ 6:12 pm
