Serato & Rekordbox ave similar features to this and it seems very cool. When playing a song, instead of check marks, highlight matching harmonic tracks with a color or a side list of matching harmonic tracks within a certain BPM range.
Thanks!
Thanks!
geposted Fri 17 Jul 20 @ 4:12 pm
You can do the sidelist.. ;)
Just drag and drop the "Compatible Songs" filter folder to the sidelist area :)
(and you can make your own limiting the filter to your own criteria, say for example same genre + compatible key. Can tweak it you your own preferences, add more stuff like date to show only recent songs etc.. )
geposted Fri 17 Jul 20 @ 4:22 pm
To show this in action
Might also be interested in "My Library" database plugin that has many such "live" updated folders, to check out
http://www.virtualdj.com/forums/189385/VirtualDJ_Plugins/MY_LIBRARY.html
geposted Fri 17 Jul 20 @ 6:11 pm
Thanks for your reply.
geposted Fri 17 Jul 20 @ 6:20 pm
