Forum: Addons
Topic: Touch 21
WWDJdkPRO InfinityMember since 2008
Discussion about Touch 21
This addon is only available with a VirtualDJ PRO or PLUS licence.
geposted Fri 17 Jul 20 @ 8:57 pm
how can i get the touch 21
geposted Thu 23 Jul 20 @ 1:31 am
You need a pro or home plus licence.
geposted Thu 23 Jul 20 @ 1:42 am
how do you get your logo to show? I added to settings logo, but it's not showing. Just keeps saying "load your logo here" on the jogwheel. thanks.
geposted Sun 14 Feb 21 @ 2:42 pm
After some investigations...
It looks like the only way is to edit skin image 'Touch-pro.png' and replace the magenta field near pixline 205 as well as the 3 other smaller bellow
and remember to use the edited skin
geposted Mon 15 Feb 21 @ 12:30 pm
With Skin set to, 4 Channel Mixer and Waveform Display set to "All 4-Decks", waveforms disappear from the top.
(becomes an empty panel with only the zoom bar to the left.)
Is that planned ?
geposted Mon 15 Feb 21 @ 1:50 pm
Hi,
i like this skin !!!
whats is the update?
Thx
GK
geposted Sun 04 Apr 21 @ 7:24 pm
you edit the .png file.
geposted Mon 05 Apr 21 @ 3:25 pm
Is that planned ?
what is color set to on the waves ? seems like it's only when its set to colors , not beat or shapes
geposted Mon 05 Apr 21 @ 3:28 pm
geposted Mon 05 Apr 21 @ 3:30 pm
Please open sharing Touch 21
geposted Fri 14 May 21 @ 5:14 am
djrxmxPRO InfinityMember since 2010
Great work, Deejay WhiteWedding! I really dig the Touch 21 UI. It's quite immersive to look at and play with, especially on a very large display (mine's a 44-inch Samsung display). Keep up the good work, brother!
geposted Wed 20 Oct 21 @ 8:23 pm
How can i get the touch 21
geposted Fri 03 Dec 21 @ 11:18 pm
This skin does a lot more things than a lot of others, especially when it comes to using it for a touch screen.
There is one drawback though and that's the BPM display. It displays the original BPM and not the deck BPM.
Is there any way this could be changed to show the deck BPM please?
Thanks.
geposted Sun 24 Jul 22 @ 4:35 pm
Hi!
I cannot find the settings button in the Touch21-skin
And minimaze/max/close buttons are mot visble (but can be pressed)
Any solutions?
geposted Tue 10 Jan 23 @ 6:39 pm
The mesh of options is on the effects button. Tap 2 times it will appear
Good luck
geposted Tue 10 Jan 23 @ 11:53 pm
Thanks for the quick answer:-)
I found it, thanks!
By the way, do you know a way to move tracks to the sidelist using the touchscreen?
geposted Wed 11 Jan 23 @ 12:53 pm
