I would love to be able to use 2 functions in 2021: the effect of showing a logo and the use of milkdrop. I was able to use them in 2020 but unfortunately they seem to be lost. I used both a lot.
geposted Fri 24 Jul 20 @ 9:20 pm
use a shader, works way better and the quality is ten fold . go into your logo and open the sample editor and select the color then turn the transparency to 12 o clock on the dial and save . then press the sample button to the sample, and have shader behind it. to make it extra wicked throw a transform effect as well on top. now your on fire....,
geposted Thu 31 Dec 20 @ 12:35 am
VirtualDJ 2021 is a 64-bit application, so that means very old outdated plugins in 32-bit no longer works (unless the plugin maker updates it)
That being said, video logo is available in VirtualDJ settings (search for logo), and you can add the Video Logo pads in extensions for easy control.And Shadertoy is a much more modern looking visualization that is also available..
https://www.virtualdj.com/plugins/index.html?addonid=81257 Video Logo control on pads
https://www.virtualdj.com/wiki/shadertoy.html Shadertoy
Some shaders that you might want to try:
https://virtualdj.com/forums/224029/General_Discussion/Questions_about_shaders_in_VirtualDJ_2018.html?page=1
and
https://virtualdj.com/forums/223454/General_Discussion/Best_visualization_shaders_for_VirtualDJ.html?page=1
and
geposted Thu 31 Dec 20 @ 11:24 am
