Hi I wish we could have the choice to not have have the key lock sound when nudging the pitch or pitch bending . Like the sound of nudging vinyl . I know in time code this is possible but i would like to have this on controller mode or on the interface it self like when using a keyboard or a mouse .
geposted Sat 25 Jul 20 @ 2:58 am
You can set the pitchQuality option to -1
geposted Sat 25 Jul 20 @ 7:10 am
Woah! -1 is basically disabling any digital pitch-key correction? How is this not documented anywhere? This is like disabling masterTempo everywhere, right?
geposted Sat 25 Jul 20 @ 1:51 pm
Not sure why anyone would want that :p
geposted Sat 25 Jul 20 @ 2:16 pm
the reason is i want to be able to have the choice to a digital sound effect or a turntable sounding effect when i pitch bend . Pitch bending in master tempo does not always sound good . If you have have a choice to use master temp or not when mixing then why wouldn't you have the same choice when pitch bending ?
Also traktor and serato have this option .
geposted Mon 03 Aug 20 @ 12:51 pm
it works thanks alot
geposted Mon 03 Aug 20 @ 12:54 pm
I Agree the manual is really incomplete . There are many things that i can't find in the manual .
geposted Mon 03 Aug 20 @ 1:08 pm
