Forum: Addons
Topic: GTS-2K21 - Page: 4
PhantomDeejay wrote :
I have coded such a view, but the browser space was too small.
I'll see if I can make it any better and port it back.
PLEAASSEEE....
geposted Tue 09 Mar 21 @ 4:11 pm
Version 1.2.4 now has 4 horizontal scratch waveforms on OSD 4 Decks layout
geposted Tue 16 Mar 21 @ 11:52 am
Can you try to rename settings.xml file to settings_old.xml and try again ? (In case a weird setting prevents them from appearing)
If that works, restore your original settings.xml file and let me know so that we can try next step
Great work with that skin!
But Im not so in programing, so can you send/make some update file to solve that problem with waveform?
Issue fixed on version 1.2.5
geposted Wed 17 Mar 21 @ 7:30 pm
one of the greatest skins ever.thank you my friend george
geposted Thu 18 Mar 21 @ 5:50 pm
Love the skin, its the closest to mimic the serato interface i feel on VDJ, one request id like to make. would it be possible to make the vertical scratch waveform display area to be a tad longer in the 2 deck swap layout. would be absolutely awesome if it could be done. or if anyone can tell me the value i need to edit in the xml that be great too.
geposted Fri 19 Mar 21 @ 2:35 am
Making the vertical waveform longer also requires to move elements like the browser further down.
So it's not as easy as changing only the height of the waveforms themselves.
I'll check if I can come with an option.
geposted Fri 19 Mar 21 @ 7:25 am
Any way to make the video screens bigger in compact view? Or in extended view use all that space for 3 big screens since we can never play 4 videos at the same time anyway. Everything else is perfect!
geposted Wed 07 Jul 21 @ 4:51 pm
Hello, i think you create one of the most profesional skin, good job !
Anyway, one thought......waveforms in mixer scratch view have only 2 option : ''color'' and ''shapes'' .
Is possible to change that in xml file and add ''rhythm wave'' ?
Regards
geposted Tue 20 Jul 21 @ 4:42 pm
Rhytmzone can't be vertical. Therefore it's impossible to add "Rhythm" as an option on mixer waveforms.
geposted Tue 20 Jul 21 @ 6:35 pm
Ok, thanks for reply !
geposted Wed 21 Jul 21 @ 10:35 am
labbedjPRO InfinityMember since 2013
Hello Love your skin. 2 suggestions 1. : Is there a way to show the waves with form or with original colors with the STEMS ON. It´s a bit confusing to have both in blue when stems are ON. 2.: A simpler beat keeper as the one on the default ( circular). Thanks
geposted Thu 21 Oct 21 @ 7:16 am
Version 1.4.0 (11/19/21)
-Added "2 Decks Split" view
- New Browser Zoom Layout with more browser space
- Added small record panel on top bar for all views
- Improved VU Meters
- Code cleanup
- Various small improvements and tweaks.
geposted Fri 19 Nov 21 @ 8:55 am
- Code cleanup
Hi Phantom. Is it suppose to LOOK like this (with the blank space in the middle of the skin) when you switch to 2 Decks Split or is it a BUG?
geposted Mon 22 Nov 21 @ 3:09 pm
No, definitely a bug. What size have you chosen for scratch waveforms ?
(Skin Menu -> Rhythm Size)
geposted Mon 22 Nov 21 @ 3:12 pm
Ok, I found the bug.
Anyway, choose XS(eXtra Small) as your rhythm size for now and I will update the skin ASAP
Skin is now fixed. Please update to 1.4.1
geposted Mon 22 Nov 21 @ 3:16 pm
Now it's good. Love your GTS-2K21 Skin. Your hard work is Appreciated...Thanks.!!!
geposted Mon 22 Nov 21 @ 7:26 pm
ymed85PRO InfinityMember since 2020
TOP!TOP!TOP!
Can U add the "prelisten panel" in the top area together with (broadcast, sandbox, etc)?
geposted Mon 22 Nov 21 @ 10:27 pm
- Code cleanup
Bam...now you got it.. This is what I was waiting for..thanks man...
new thought different variations of this. Keep Building...to the moon...lol
geposted Tue 23 Nov 21 @ 1:34 am
is there a way to make the browser font a lighter color
geposted Sat 18 Dec 21 @ 2:45 am
Version 1.5.0:
-Added "2 Decks Compact" layout ("2 Decks Split" layout clone, with wide waveforms)
-Added two new browser color schemes (Bright White & Bright Blue)
-Added custom prelisten player as an option on the top bar central area
geposted Tue 04 Jan 22 @ 10:23 am
71%
