Forum: Addons
Topic: GTS-2K21 - Page: 3
The TAB buttons should still work. However there's no visual indicator on this skin as it's designed mostly for use with controllers and not keyboard mixing.
Best skin ever indeed. Thanks much
Could really do with some custom buttons though
(I do understand that it is performance-based and for use with controllers, but I don't always have my controller connected)
Cheers
Have you pressed the CB button on top left of the skin?
It enables a hole row of custom buttons
Totally missed that
Thought i been through everything. Still full of surprises
Again, Best skin ever
Is it possible on the 4 deck center wave form to change the layout of the waves. As of now it's 3124 is it possible to make it 1,3,4,2? Or can you tell me where and how to change that in the XML file?
Just in case you ask why; I'm going to use my vci400 as mixer with 2 denon3900s. The 3900s will be channels 1 and 2 the vci400 decks will be 3 and 4. So I wanted that to be reflected in the skin.
did you try the setting "mixerOrder" in controllers section ?
Scratchwaves are indeed using a hard fixed order.
I will add an option to change.
I'll surely be waiting, thank you.
I hope those options cover everybody's needs...
Thank you sensei...
Can we have the bpm grid edit options when you right-click in bpm area?
Original OSD BPM Editor is too big to fit.
I will try to think of something to include it though...
Using the main skin as example
You click the bpm number and appears
Edit Tap
you can add
*2 /2
That should fit in that popout display....maybe..lol
Not the best solution, but still... All functionality is there (and I don't think anyone will need OSD BPM Editor active for more than one deck at the time)
How do I get to it? I been searching can't find it.
Right click on BPM value on a deck.
Where it had always been (just not in 4 decks view before)
PS: That's a standard function on all my skins. I thought you knew it and that's what you asked for...
Can you try to rename settings.xml file to settings_old.xml and try again ? (In case a weird setting prevents them from appearing)
If that works, restore your original settings.xml file and let me know so that we can try next step
Great work with that skin!
But Im not so in programing, so can you send/make some update file to solve that problem with waveform?
Hate to be a pain... Is there a chance to get 4 waves visible in the central area on the 4 Deck OSD or even 4 independent waves under each deck xs size. Actually both choices.
I have coded such a view, but the browser space was too small.
I'll see if I can make it any better and port it back.
53%
