Discussion about Stems Controller
stems controller - remote skin
geposted Sun 26 Jul 20 @ 12:15 pm
You're now able to control the stems using this remote skin.
Resolution is set for an iPad although if you'd like alternative resolutions please post below. If and when I get time I'll see what I can do.
geposted Sun 26 Jul 20 @ 12:55 pm
I like how the "kick" icon is actually a snare drum :-)
[DAN] I didn't chose the icons. I used the ones that VDJ was using in the advertising materials etc ;)
[GROOVINDJ] Yes it made me chuckle when I saw the ad running on DJWORX.
geposted Sun 26 Jul 20 @ 12:58 pm
Habe ein altes Samsung TAB 4 und läuft gut darauf. 👍
geposted Sun 26 Jul 20 @ 1:31 pm
Control mode > small / large
Appear offset to the left on my tablet
geposted Sun 26 Jul 20 @ 2:07 pm
Nice one !
What is the yellow square top left ?
Title and artist appear really big and truncated vertically
(had to fix to make them fit in height) respectively
<text fontsize="22"
<text fontsize="20"
by the way added a visibility="loaded" to prevent "drag a song..." to appear
and notice slider don't have fill ?
https://imgur.com/a/eMgCqXU
<text fontsize="22"
<text fontsize="20"
geposted Sun 26 Jul 20 @ 2:10 pm
Your bleed fader looks very small too. What device are you running it on?
Also @Dan it's separation, not seperation. :-)
[DAN] Fixed in next build
geposted Sun 26 Jul 20 @ 2:14 pm
PC... ^^ (It's in my skin addon plugin)
geposted Sun 26 Jul 20 @ 2:19 pm
Mark - can you upload a screen capture please.
geposted Sun 26 Jul 20 @ 2:25 pm
OK figured out the utility of the yellow square ... It will only appear on remote when renderer will be able to handle shapes in remote skins
geposted Sun 26 Jul 20 @ 2:26 pm
Nicotux wrote :
Nice one !
<text fontsize="22"
<text fontsize="20"
<text fontsize="22"
<text fontsize="20"
The yellow box will be removed on next build - but you probably already did it.
It was a test to see whether <visual><square> worked in the remote - which they don't. Only you will see this with your plugin.
Worth remembering that the Remote skin engine is not as advanced as the VDJ main skin engine. Hence (I think) why you are seeing these other anomalies on the sliders and "fontsize" is not supported in the remote skins.
geposted Sun 26 Jul 20 @ 2:28 pm
Some time ago now, we were told that the remote app would be getting an update. Is work still being done on it?
geposted Sun 26 Jul 20 @ 2:31 pm
Adion stated probably about a month ago that nothing had been done. We can now see why with the new release.
geposted Sun 26 Jul 20 @ 2:56 pm
The skin itself will display fine in a remote app environment.
Nicotux used a custom plugin on a PC to display the skin, hence the anomalies.
I have no idea if an update is in the works.
geposted Mon 27 Jul 20 @ 1:17 am
Thank you Dan.....
geposted Mon 27 Jul 20 @ 8:02 pm
stupid question, how do I get this on my tablet?
geposted Thu 17 Sep 20 @ 6:26 am
By buying and installing the remote app
settings -> REMOTE (select your store) or directly from your tablet
then
setting -> Extensions -> Skins -> Remote App
then
settings -> INTERFACE -> Remote skin
then
then
geposted Thu 17 Sep 20 @ 8:46 am
Would I be able to control 4 decks of stems?
geposted Mon 09 Nov 20 @ 1:24 am
it is designed to work for deck left and deck right (2 decks at a time what ever their letter/Order number are)
so that
- if you use 4 decks in swap mode the answer is YES
- if you wanna control all 4 decks at the same time the answer is NO
so that
geposted Mon 09 Nov 20 @ 2:28 am
so that
so that
Thank you. Glad I asked this question.
geposted Tue 10 Nov 20 @ 8:38 pm
