I plugged a microphone into the mic socket of my computer to go with my webcam as the audio through the camera is no good I then went into audio settings it said that I needed a analog licence the video from the camera works well and WHY a licence is needed just for a microphone.
geposted Fri 31 Jul 20 @ 7:32 pm
Analog license, usually means you have set up independent deck outputs (Aka, for analogue external mixer, and hence pro dj gear, license required).
Maybe you just set up wrong audio settings?
If you are not using any external DJ mixer or gear (that will require a license), your sound setup should Master output (+ possibly headphones)
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/masterheadphones.html
For connecting microphone, simply add input mic.
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/microphone.html
Typically having Deck 1 and Deck 2 as independent output of the sound card, will ask for a license.
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/externalmixer.html
geposted Fri 31 Jul 20 @ 7:46 pm
Thanks for your reply I will look into it.
geposted Fri 31 Jul 20 @ 8:47 pm
