Appologies if this has been asked before, I've struggled to find any detail but basicly my question is:
- Is there a way of setting Sample audio to play automatically at a set point during an audio track i.e at a cue point ?
Many thanks.
Many thanks.
geposted Sun 02 Aug 20 @ 12:23 am
Yes,
if it's for a specific track you can add an action POI
i.e.:
sampler_bank 'xxx' & sampler_play n
if you want a specific sample every time a cue point with a specific name is reached whatever the track is it's a bit harder
i.e.:
geposted Sun 02 Aug 20 @ 4:54 am
As mentioned you can use the POI ("point of interest") to set markers to do any action
https://www.virtualdj.com/manuals/virtualdj/editors/poieditor.html
And play a sample at a "cue point".
If its more like a radio jingle, that you want to play through your show, or DJ drop, you might also consider the Event Scheduler, that is made for such things ;-)
https://www.virtualdj.com/manuals/virtualdj/interface/topsection/appcontrols/eventscheduler.html
geposted Sun 02 Aug 20 @ 1:01 pm
