Strange report from CPU meter
https://imgur.com/GN6zlwa
Yes my skin is using intensive (hugely) drawing but 2.4 fps is weird and little abusive
video @ 55.8fps (when set to 30 in settings and a 29.97fps video loaded not playing)
where 1352.7 theorical is ... really weird and mainly erroneous
everything with 35.7% CPU (global)
Why the hell do the 64.3% remaining CPU power is not used ?
Sure this extra CPU power as well as the extra (GPU?) one used for video would be usefull to draw skin faster in some way
geposted Wed 05 Aug 20 @ 2:07 am
Which skin did you use?
Did you use the 64-bit version?
Does experimentalSkinEngine make a difference?
Which cpu do you have?
Note that with multi-core cpus windows reports system cpu usage as total over all cores.
So on a quad core, 25% might mean 1 core is fully occupied.
geposted Wed 05 Aug 20 @ 7:06 am
I know this is extremely uggly, verry high power consuming and not so much power present but i'm in "still usable" range
Which skin did you use? : My latest "VB_8Decks"
Did you use the 64-bit version? yes VDJ-64 b6042 (because of stems needed)
Does experimentalSkinEngine make a difference? yes, incontrovertibly
- video 30fps as expected ( >900 theorical)
- skin up to 75fps with no track loaded only 2 extra windows, 50 fps when loaded, 24fps playing which is usable
- when all 8 video windows are open (everything empty, video not activated) skin 60fps system 11%
- when all 8 video windows are open (everything empty, video activated, no effect) skin 60fps ..100fps video 32 fps (theorical >1100fps) system varying 15%..35%
- when all 8 video windows are open (1 or up to 8 video loaded, no effect) skin 60fps stable video 32 fps (theorical >1400fps) system varying 25%..30%
- THERE IS NO VIDEO ON FULL EXTRA WINDOWS (previews part of other window showing) until window was resized
- when all 8 video windows are playing (1 or up to 8 video loaded, no effect) skin 60/nb fps stable video 32 fps (theorical >100fps or >500 depending on ??) system <65%
- some drawing effect (same drawing define used) not present everywhere or rendering differently, some transparent areas visible, some drawings over transparent hidden
CPU: old Gen2 i5-2400S @2.5GHz with combo nvidia geForce 525m
4 cores are used in a balanced way (no difference)
geposted Wed 05 Aug 20 @ 2:55 pm
