The container "<rack>" works fine in horizontal by default
one unit by visible element, one panel per size depending on number of elements to display (global width / nb)
<rack name="rack1">
<unit name="unit1" >
<panel ...1
<panel ...N
</unit>
<unit name="unit2" >
<panel ...1
<panel ...N
</unit>
<unit name="unitN" >
<panel ...1
<panel ...N
</unit>
</rack>
is there a way to do the same vertically (parameter like orientation= or direction= or group= )?
EDIT: original title was "<Rack > orientation" forgot site remove > and < from titles :/
<rack name="rack1">
<panel ...1
<panel ...N
</unit>
<panel ...1
<panel ...N
</unit>
<panel ...1
<panel ...N
</unit>
</rack>
geposted Thu 13 Aug 20 @ 6:47 pm
Up until now I have always wondered what a rack is in VDJ.
Can you explain that to me in more detail?
I have never found this in a skin until now, just seen the mapping command.
Would interest me.
Greetings Dani
Would interest me.
Greetings Dani
geposted Fri 14 Aug 20 @ 1:17 pm
It's been a long time since i used Racks in this skin too.
geposted Fri 14 Aug 20 @ 1:21 pm
No found...
Only in Mapper the Command.
Can you explain that to me in more detail what it is?
geposted Fri 14 Aug 20 @ 1:39 pm
Yes djdad, that's where i got the infos :)
never saw it anywhere else ^^
rack allows multiple panels to share the same area at a time, one being prioritized showing at different size depending on visible panels
I explain:
say you have 4 panels
you can display at full size one panel
at 3/4 1/4 when 2 panels selected
at 1/2 1/4 1/4 when 3 panels are selected
and 1/4 1/4 1/4 1/4 when 4 panels are selected
any panel can take preference (rack_prioritize)
any panel can hide or show (rack)
any panel can overrite the other settings (rack solo)
of course all 4 panels have to define in all 4 sizes
@djdutschi
More infos were in french and italian forums ... a long time ago and disappeared
still remain quick description in the wiki for VDJscript verbs under skin section:
https://virtualdj.com/wiki/VDJscript_verbs_v8_p2.html
I explain:
@djdutschi
geposted Fri 14 Aug 20 @ 1:49 pm
I explain:
@djdutschi
I explain:
@djdutschi
Thanks , I will look and lern there from what it is ;-)
geposted Fri 14 Aug 20 @ 1:57 pm
Here it is in action with songpos in 4 decks mode with 4 first deck displaying (over 8) and deck3 prioritized
https://imgur.com/a/QLQP4rK
as you can see, decks 1 and 2 and 4 are 1/8 the total size and deck 3 is 1/2 the total size
geposted Fri 14 Aug 20 @ 2:14 pm
