Hi.
I have a skin with 6 decks
Is there a script i can put on a button so that when i select deck 5 as the master the button makes deck 5 master and pause all the other decks.
I would like to to put sush a button for each deck.
geposted Fri 21 Aug 20 @ 5:42 am
deck 5 play ? deck all pause & deck 5 play : deck all pause
geposted Fri 21 Aug 20 @ 5:59 am
Cool so i will use the string exactly like that
Ill just change the number 5 to the number of the deck it applies to
Will this also select deck 5 as the master deck? Because i have one set ofvplay pause and stop buttons for all 6 the decks the work with the deck that is set to master
geposted Fri 21 Aug 20 @ 7:11 am
If you gave a good explanation of your requirements in the first post, rather than filling in the blanks later, people would be able to give you a suitable answer.
Also, why have you made a new post to ask this? You could have continued in your existing thread.
geposted Fri 21 Aug 20 @ 7:28 am
