Hi All,
I use the very simple 'Dance Infinite' skin.
The time left flashes when there is 30 seconds of track left.
Is there a way to make the Waveform flash at the same time?
Thanks
Thanks
geposted Fri 21 Aug 20 @ 4:41 pm
Can do pretty much anything in skin, if you edit it yourself.
Look at the already flashing parts, and add that to skin element, should probably work ;-)
geposted Fri 21 Aug 20 @ 4:59 pm
Project X skins do this by default. But yes any skin can do it with the right code.
geposted Fri 21 Aug 20 @ 7:49 pm
But, when the waveform is flashing, it will disturb you, if you want to "visually" synchronize the next track.
geposted Fri 21 Aug 20 @ 9:44 pm
The default layout/skin has blinking jogwheels
Should be plenty ;-)
geposted Fri 21 Aug 20 @ 9:52 pm
Ahh yes, but I have disabled them in the menu......too easy to accidentally touch them whilst playing.
geposted Sat 22 Aug 20 @ 1:31 pm
Thanks Guys
It's working out the code that is not my strong point.
Guess I'm looking for some help on that....
geposted Sat 22 Aug 20 @ 2:12 pm
