OK, have progressed with the previous problems, but I still have an issue with Deck 2 and no audio.
I am running VDJ Pro on a Mac with operating system Yosemite. I have selected the controller and have deck 1 assigned to channels 1 & 2 with deck 2 on channels 3 & 4. Deck one works fine. Deck 2 works but there's no audio.
I am using a Denon DN-HC4500
Can anyone offer any advice/insight as to why this is and how I can get it fixed?
Thanks a million
Thanks a million
geposted Mon 24 Aug 20 @ 4:24 pm
Still using that old thing eh? Did it ever require drivers for Mac?
If it didn't then you probably just need to set it as a four channel device in your Mac audio config.
geposted Mon 24 Aug 20 @ 4:31 pm
Its a very old controller.
See here :
https://www.virtualdj.com/forums/229605/VirtualDJ_Technical_Support/Denon_HC-4500_and_Windows_10.html
Will work, but you need a little bit of tweak to it, if you read above thread it should be explained there ;-)
Requires to be setup as multi-sound in Windows/Mac, and sensitive to khz settings if I remember right ...
See here :
geposted Mon 24 Aug 20 @ 4:32 pm
It works perfectly well! Used in a studio, so none of the new things are any good, as don't need a mixer etc...
thank you for the link, however I am using a mac. It didn't drivers no, and I have updated the firmware.
geposted Mon 24 Aug 20 @ 4:34 pm
geposted Mon 24 Aug 20 @ 4:36 pm
Weird that deck 1 works OK. Deck 2 works but no audio.
If I change the settings to all work on one channel, that's fine, but in a radio environment, that's not always best
Any help very much appreciated
geposted Mon 24 Aug 20 @ 4:37 pm
groovindj wrote :
Thanks for this, although nothing on there applicable sadly. The audio output on the mac is set to the 4500 and as I mentioned, it does work fine when either selecting 'speaker output' or just playing deck 1... if you try and do separate decks, there's no audio on 2
geposted Mon 24 Aug 20 @ 4:42 pm
1. Go to Applications >> Utilities >> Audio MIDI Setup
2. Select DN-HC4500 from the menu on the left
3. Make sure under "output" you have the following setting for "format": 44100.0 Hz, 4ch - 16bit
If you have done all that, maybe post a screenshot of your sound settings?
geposted Mon 24 Aug 20 @ 4:45 pm
Rune, you are officially a GENIUS!
Tusen takk for hjelpen
It worked!
geposted Mon 24 Aug 20 @ 4:58 pm
Most welcome ;-) and good Norwegian ..hehe
geposted Mon 24 Aug 20 @ 4:59 pm
Yes it was applicable. It was the same info that Rune posted after me.
geposted Mon 24 Aug 20 @ 5:01 pm
I can't find utilities. Where is it at?
geposted Tue 30 May 23 @ 6:12 pm
MacOS has changed like a hundred times since that post.
Search for midi, will be something there no doubt.
geposted Tue 30 May 23 @ 6:54 pm
