Hi,
DDJ 1000 : V 1.07
VDJ : V 6076 or V 6067 on OSX
Problem with FX REVERB problem :
FX_SEL_REVERB
if you select REVERB on, and turn DDJ1000 FX KNOW selector to another FX : VDJ KEEP REVERB on. -> BUG
with other FX-SEL FX not the problem, the other effects stop as soon you select another with FX KNOB selector....
It's Dangerous in a MIX (REVERB still activated when you change FX on DDJ 1000)
The script mapping seems to be ok, so the BUG is not in the mapping, but in Script function in main code....
Easy to reproduce with DDJ1000 latest firmware 1.07
Regards,
Olivier F.
DDJ 1000 : V 1.07
FX_SEL_REVERB
Regards,
Olivier F.
geposted Tue 25 Aug 20 @ 9:48 pm
Hi,
bug stll present in V6090 early updates (2/9/2020)
geposted Wed 02 Sep 20 @ 10:20 am
Hi,
many thanks, it works with your file :)
Regards,
Olivier
Regards,
Olivier
geposted Thu 03 Sep 20 @ 8:13 pm
