I have Pioneer djm-5000, is a midi mixer with asio audio card.
In Virtualdj 8 i haven't configuration problem but....
Why Virtualdj 2021 do not accept my Mixer driver?
geposted Wed 26 Aug 20 @ 7:06 pm
Says error creating asio channels.
Make sure the sound card of the 5000 is not already taken and in use by other programs, for example taken as Windows default sound card ...
Its an old mixer, but should still work ok ;-)
(and that you have latest drivers
https://www.pioneerdj.com/en/support/software/djm-5000/
and you might be interested in mapper, although not strictly needed
https://virtualdj.com/addons/16277/Pioneer_DJM-5000_(3-1-2-4).html )
geposted Wed 26 Aug 20 @ 8:01 pm
Hello, I have the same problem.
geposted Wed 17 Mar 21 @ 6:28 pm
Make sure the sound card is not taken by other apps or as Windows default sound card
geposted Wed 17 Mar 21 @ 6:39 pm
I also have this problem as you solved it?
geposted Sun 24 Apr 22 @ 6:06 pm
New laptops, fresh Virtual dj and...sound only from chanel 4 :(
With old Virtual 7 no problem, work like a champ.
Any ideas ?
Any ideas ?
geposted Tue 26 Apr 22 @ 2:54 pm
Probably the driver is just 32 bit, so try VDJ 32bit
geposted Tue 26 Apr 22 @ 3:31 pm
