I know I already reported but didn't find my old post
As the custom button name with backquote are broken ( no text before, no multiple backquote, no text allowed after...)
instead of the simple (i.e. as for a pad name)
Width `skin_width`
horrible things like that are needed :
`param_add "skin_width & param_cast text" "get_text ' Width '"`
or worth
`param_add "video_level & param_cast percent & param_cast text" "get_text ' Video '"`
instead of simple
Video `video_level & param_cast percent`
It would be fine they work the same as pad names (with fix for their own bug with first backquote needing at least one char before it to work)
Other thing :
in custom button context selectionmenu popup , the script appears instead of name, would be more friendly to see the value instead of some unreadable great line of code
Width `skin_width`
or worth
instead of simple
Other thing :
geposted Sun 30 Aug 20 @ 7:31 am
