Hello, 2020 and 2021 Ver. I want to play a slideshow during a music video's playing WITHOUT having the music video bleed through. Also, I need to be able to start the slideshow on the first slide in the folder every time instead of random starting points. The slideshow seams to continuously cycle through pictures even when not in use. Thank you.
geposted Sun 30 Aug 20 @ 9:01 pm
For the bleed, you can map custom slider in the skin with the action :
deck master video_level
That will let you fade the "background" videos to black, and only have slideshow to video output
Try turn off Shuffle, in the Slideshow FX settings, perhaps that starts on 1st and in order.. ( I didnt try myself, but give it a go..)
geposted Mon 31 Aug 20 @ 1:53 pm
Depending on the aspect ratio of your slideshow content, you can try to set letterBoxing setting (from VDJ Settings->OPTIONS tab) to Zoom. This will make Slideshow to cover the entire screen.
For the starting point, indeed there is no option for that at the moment, but may be added in the future.
geposted Mon 31 Aug 20 @ 1:57 pm
