I'd like to see someone develop an ability to rotate your log for VDJ 2021
geposted Mon 31 Aug 20 @ 1:50 pm
add your logo to your image skin/video skin
then add somethings like this
<visual x="[X]" y="[Y]" width="[SIZE_W]" height="[SIZE_H]" type="rotation" source="get_constant [ANGLE]" >
<down x="[LOGO_X]" y="[LOGO_Y]" [width="[LOGOSIZE_W]" height="[LOGOSIZE_H]"]/>
</visual>
to the skin
X Y coords of the logo on screen
SIZE_W SIZE_H size of logo on the screen
LOGO_X LOGO_Y position of logo in the image file
LOGOSIZE_W LOGOSIZE_H optional size of logo in the image (to be resized)
ANGLE in radians
you can change source to whatever you want .. i.e. (rsi counter , beat, position, time....) to make it rotate endless
i.e.:
<skin name="ROTATING LOGO" version="8.4" author="Ntx" width="1920" height="1080" image="VDJ.png">
<copyleft>(c)2019 - Nicotux </copyleft>
<video x="0" y="0" width="1920" height="1080"/>
<visual x="100" y="100" width="192" height="192" type="rotation" source="get_clock 1000 & param_multiply 0.0001 & param_cast frac">
<!--OR source="get_clock 1000 & param_multiply 0.0001 & param_cast frac" & param_multiply 3.14" ROTATES wait rotates -->
<!--OR source="get_constant 0.87654" fixed -->
<down x="0" y="0" width="172" height="52" />
</visual>
</skin>
</visual>
to the skin
ANGLE in radians
i.e.:
</visual>
</skin>
geposted Mon 31 Aug 20 @ 3:01 pm
VDJ.png is small 172x52 VDJ logo resized to 192x192 in this case, adapt to your needs
and angle is not in RADIANs but GRADs/100
geposted Mon 31 Aug 20 @ 3:06 pm
I think the OP wants his custom Logo to rotate on the Video output
geposted Mon 31 Aug 20 @ 3:21 pm
just change the logo in image=
and specify original size in <down if it's not the same size as <visual
geposted Mon 31 Aug 20 @ 3:25 pm
Hi, need help please. When I define LOGO it not works. tryin use this
<!--LOGO--> ????
<define class="logo">
<deck deck="Master">
<size width="400" height="200"/>
<pos x="+0+1060" y="+0+750"/>
<down x="0" y="1080"/>
</deck>
</define>
<!--LOGO EFFECTS-->
<group name="logo">
<stack fadein="2500ms" fadeout="2500ms">
<pos x="0" y="0"/>
<slot x="+0" y="+0"/>
<item class="logo" visibility="yes"></item>
<item class="logo" visibility="load_pulse_active 1000ms 156000ms && pulse 23000ms"></item>
</stack>
</group>
Can anyoe help please?
<!--LOGO--> ????
</deck>
</define>
<!--LOGO EFFECTS-->
<group name="logo">
<pos x="0" y="0"/>
</stack>
</group>
geposted Mon 02 Nov 20 @ 10:57 am
<!--LOGO--> ????
</deck>
</define>
<!--LOGO EFFECTS-->
<group name="logo">
<pos x="0" y="0"/>
</stack>
</group>
<!--LOGO--> ????
</deck>
</define>
<!--LOGO EFFECTS-->
<group name="logo">
<pos x="0" y="0"/>
</stack>
</group>
geposted Mon 02 Nov 20 @ 2:37 pm
