Editing the karaoke.xml file, what is the command to have the ‘will play at’ time displayed on the singer’s rotation list on the karaoke skin?
At textzone after the song title I tried,
<text size="38" font="Arial" color="#ffff00ff" action="get_next_karaoke_song 'will play at' 2" />
But this does not show anything. What am I missing? I will appreciate any help.
Ralph
Ralph
geposted Thu 10 Sep 20 @ 2:05 pm
did you , or anyone, ever figure this out?
i tried...
'willPlayAt'
'will_play_at'
'will play at'
'will%20play%20at'
anyone?
i tried...
'willPlayAt'
'will_play_at'
'will play at'
'will%20play%20at'
anyone?
geposted Mon 12 Jul 21 @ 10:11 pm
yes, someone ^^ figure out may never come (or the way to get it is hidden)
Asked many times for years with no success
Same to be able to write to "Singer" and "Key Change" fields by script
geposted Mon 12 Jul 21 @ 11:31 pm
There is no 'will play at' for karaoke, since the pause between singers is not known.
geposted Tue 13 Jul 21 @ 6:02 am
LOL
So that why is there a song "Length" field as scratching and loops and other cues and scratchbanks that will be used during mix are not known and why does sidelist have 'will play at' ? x^)
Automix evaluation is wrong in dual deck mode as well
History playlists have 'will play at' oO is that really normal or strange ?
And yes karaoke have a 'will play at' column, just can't be read
Using an extra window showing 'karaoke' sideview pan only can show it because the column exists ^^
(that's why there is a dedicated display for that in my skins and the reason I tried to put it in a videoskin)
As for other lists, this is only an evaluation of playing time, really useful to make people ready and aware of the remaining time they still have in a way to do things... toilet, cigarette, bar, extra dessert, dance...
There are always some people in front of this display
geposted Tue 13 Jul 21 @ 6:57 am
Fair enough, will add to get_next_karaoke_song
In history lists it was supposed to read 'play time' instead of 'will play at', will check what happened there
geposted Tue 13 Jul 21 @ 7:44 am
in fact there are both
geposted Tue 13 Jul 21 @ 7:47 am
