Are the bleed settings taken into account when stems are precomputed?
Also, with precomputed stems can the bleed be altered?
THanks
THanks
geposted Thu 10 Sep 20 @ 8:58 pm
That is a good question - especially since I asked the same one when the pre-compute feature was released, and got an answer from the devs :)
Yes, it can still be altered with precomputed stems
So basically your current bleed settings works the same regardless if your stems are "freshly made" or pre-computed
I guess that also means that bleed settings are not taken into account when stems are being precomputed - or at least it doesn't really matter
geposted Fri 11 Sep 20 @ 7:21 am
THanks
THanks
Like Klaus said..
They work same way as "live stems" (generated on the fly stems).
So you can use precomputed stems exactly same way as non-precomputed. Alter bleed etc when in use ;-)
geposted Fri 11 Sep 20 @ 12:41 pm
Thanks all for your answers.
geposted Sat 12 Sep 20 @ 2:31 am
