Just a few questions regarding the new TIDAL integration:
- Does it support the HIFI (lossless) option you can get with a more expensive subscription?
- Does it support TIDAL videos?
- Is it on purpose that it's not in the ALTERNATIVE REMIXES provider list?
geposted Fri 11 Sep 20 @ 7:36 am
Currently it will use the high quality streams all the time.
Lossless and video are not available at the moment, but we're checking if we can support this.
Remix providers will be updated in the next update
geposted Fri 11 Sep 20 @ 7:39 am
Hi, just adding to this thread.. how do i get to see Tidal videos in the Virtual DJ application?
thanks
thanks
geposted Wed 30 Sep 20 @ 11:58 am
Only Audio is currently supported
geposted Sun 04 Oct 20 @ 11:11 am
Any update on when lossless might be available with tidal or deezer. Or any for that matter.
muchos gracias
geposted Thu 03 Dec 20 @ 5:28 am
please, when will they bring online video integration to mix in virtual dj. Tidal has great videos. if you can bring it in 720p it's already great to play. Thanks in advance
geposted Sat 21 Jan 23 @ 11:38 pm
Asked for this several times now. I have found though that the Tidal videos are straight off YouTube and not edited for DJ use.
geposted Sun 22 Jan 23 @ 12:03 am
Hello are there any plans to enable Tidal videos on Virtual DJ? If so, what is the timing?
Thank you
Thank you
geposted Sun 28 Jan 24 @ 10:11 pm
I'm using Tidal Videos on my Live Video Show, on location. It's brilliant!
Unfortunately there's no video option to be broadcasted on Virtualdj, just audio as spected, so I do a Radio Show on streaming instead
geposted Sun 28 Jan 24 @ 10:46 pm
