Math engine wont change to CPU. 2nd time this is happening. Had to reinstall virtual DJ to get it to change 1st time. but lost all my personalized settings
geposted Sat 12 Sep 20 @ 3:08 am
What is your computer specs?
geposted Sat 12 Sep 20 @ 3:00 pm
Lenovo ThinkPad
Intel Core i5-6200U CPU @2.3 GHz 2.4GHz
4GB RAM
Windows 10 Pro Version 1903
geposted Sat 12 Sep 20 @ 6:33 pm
Odd, 6th gen Intel should be plenty for CPU with the mathengine.
Sure its not GPU you tried?
Also make sure you have the very latest updates, since there been quite a few fixes since day one
geposted Sat 12 Sep 20 @ 7:51 pm
the issue i had is... forcing option to GPU when GPU can't be used (i5 Gen4 + AMD) goes in a recusive box opening to say GPU is not compatible
had to kill vdj, manually reset to GPU in settings.xml to make VDJ work again
IMO when bad config is detected VDJ should go automatically to back to 'disabled' or 'auto'
geposted Sun 13 Sep 20 @ 12:02 am
Math enginer error ???????
Stems not work
Stems not work
geposted Sat 14 Aug 21 @ 4:51 pm
Yes just happened to me also,I have a mac bookpro 2017 delete the old version get the new one 2021 but says that Math Engine error, I dont know how to fix it.😔
geposted Mon 16 Aug 21 @ 10:02 pm
have this Now after update....&Stems not working on my MAC book Pro
geposted Wed 18 Aug 21 @ 1:05 am
What MAC OS version are you using ?
You need at least 10.14 (Mojave) for stems separation.
geposted Wed 18 Aug 21 @ 7:21 am
Maths engine error
geposted Wed 31 Jan 24 @ 12:48 am
