Ok, I have searched through the forums and I can't find an answer, so here I am.
Im looking to buy a new computer with a Ryzen 5 3500u processor but I want to make sure VDJ will be compatible.
There seems to be no mention of AMD compatibility anywhere.
geposted Wed 16 Sep 20 @ 11:29 pm
VirtualDJ works fine with AMD processors ;-)
geposted Thu 17 Sep 20 @ 12:34 am
awesome. Thank you!
geposted Thu 17 Sep 20 @ 1:32 am
Can anyone help? I have just upgraded from MT3 to MT Platinum FX using Virtual DJ 2021 on a Dell Inspiron 15 3505 on Windows 10. For some reason the cue buttons not working correctly. When I press cue the sound is still coming out of speakers, feintly. Also when cue is selected it disabled the volume control. does anyone have any suggestions? As it works perfectly with my old Dell laptop, but it’s kind of slow and I need the spoed from the new one. Any help will be gratefully appreciated
geposted Fri 05 Mar 21 @ 1:20 pm
Not sure why you posted in AMD thread, its likely not related to that ;-)
Check that you have correct audio setup, see here:
https://virtualdj.com/manuals/hardware/numark/platinumfx/setup.html
and with images see here: https://www.numark.com/kb/article/2229 (similar settings)
geposted Fri 05 Mar 21 @ 1:37 pm
Apologies, I’m a newbie and just needed some help. I’ve tried all the options and still no change. I’m unsure what else to do next
geposted Mon 08 Mar 21 @ 5:47 pm
What is your current sound settings in VirtualDJ?
geposted Mon 08 Mar 21 @ 5:54 pm
