I have a Denon HC 4500 Control and when I try to run it with virtual dj, I get no sound when selecting the asio driver.
I'm using Virtual Dj 2020 8.4.5647 still don't update it to 2121
Thank's
Thank's
geposted Fri 18 Sep 20 @ 3:01 am
Since June 2019 build 5044 a certain Denon ASIO driver has been blocked due to stability issues.
djdad wrote :
The driver that is blocked due to stability issues is the one named as "DENON DJ ASIO Driver" and affects the controllers HC4500, HC5000, HD2500, X-1600, MC3000, MC6000, S1200, S3700, SC2900, SC3900
For all the above controllers, even if its ASIO driver is installed, VirtualDJ will ignore it and use the WASAPI WIndows driver, which in our tests works just fine.
Every other Denon controller which offers a (different) ASIO driver (including MC4000 and MCX8000) will work as it was already.
geposted Fri 18 Sep 20 @ 6:19 am
